Old 08-20-2008, 11:18 AM
Jerry Jerry is offline
displaymode() problem
I am using the ProcessUtil module to start a script from within another
script.
The main script is
from viz import *
import ProcessUtil
go(STEREO | HMD)
g = add('gallery.ive')
def onKeyDown(key):
	if key == KEY_RETURN:
		ProcessUtil.runScript('foo.py')
and the script it runs (foo.py) is
from viz import *
displaymode(1280,480,16,60)
go(HMD | STEREO)
g = add('court.ive')
The problem is that each time you press RETURN to run foo.py,
when you exit from foo.py and return to the main script
the viewpoint is raised relative to what it was before foo.py was run.
If you comment out the displaymode line in foo.py the problem goes
away, but it will have to remain in the actual application I am using.
Any suggestions on how to fix this?
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
