Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 06-22-2008, 09:34 AM
dan12345 dan12345 is offline
changing between avatar states
Hi, i have two problems i have bumped into :
1. i want the avatar to change between one state to another, wait a few seconds, and then return to its original state. how can this be done?
avatar.state(newState)
wait = vizact.waittime(3)
avatar.addAction(wait)
avatar.state(oldNum
did not work.
2. another problem i have, that the 2 state differ in the orientation - one of the states is facing forward and the other is facing backwards. to solve this
, i tried rotating the avatar just before changing the states, but this caused
an animation bug - since now it actually rotates BEFORE the animation swapping takes place, which is not the result i had wanted ( to make things clear, what happens now is that the avatar first rotates instantly around, and then makes a strange twirl in order to face the right direction ). How can i solve this?
Thanks!
Old 06-23-2008, 01:39 PM
1) The easiest method would be to use a task. Here is some sample code:
avatar = viz.add('vcc_female.cfg',pos=(0,0,5),euler=(180,0,0))
import viztask
def AvatarTask():
	avatar.state(2)
	yield viztask.waitTime(3)
	avatar.state(3)
viztask.schedule(AvatarTask)
2) Ideally, all your animations should start and stop facing the same direction. By default, when you transition between animation states, the avatar will blend between the current pose and the new animation pose. The quick turn you see is due to this blending. There is an optional delay parameter in the avatar.state command which controls how long the blending should take place. Try setting it to 0, it should remove the blending.
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 09:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 05:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 08:48 AM
avatar neck too short aa-chris Vizard 2 10-16-2007 09:28 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 04:06 PM
