Old 05-21-2008, 03:16 AM
Roelie Roelie is offline
Problem loading .wav when using .speak
Hello!
I am completely new with Vizard, so I am working through the tutorials right now. When I load the .py file for simple lip-synching (created by you), I keep getting the same error: Failed to load wave file: jfk.wav
What is the problem here? Does it not recognize the file, is the file in the wrong folder, or did I forget to start a certain library necessary for these actions?
I hope you can help me out. Thanks!
Roelie
Old 05-21-2008, 07:13 PM
Are you using version 3.00.2701 or later of Vizard? There was a bug in older versions where the speech action wouldn't be able to find wav files in the resource folder. If you do have the latest version, can you verify that you have the file jfk.wav in the [Vizard30]/resources directory?
Old 05-22-2008, 01:10 AM
Version 3.00.2167
I have an earlier version than the one you mention: Version 3.00.2167
So what should I do next? Is there a way to solve this problem?
Old 05-22-2008, 11:34 AM
The easiest solution is to download the latest version of Vizard. If you can't do that for some reason, then copy jfk.wav into the same directory as your script.
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 05:22 PM
Script loading problem JRichizzle Vizard 1 03-12-2004 11:03 AM
something to add to your docs re: .wav files and lip flapping rosanna Vizard 0 11-19-2003 05:15 PM
