Old 05-04-2008, 04:46 PM
TheLostBrain TheLostBrain is offline
Unhappy Flock of Birds (Only Position Tracking working? No Orientation?)
Hi.
I just downloaded the WorldViz demo and I'm trying to test out the Ascension Technology Flock of Birds Support.
I'm using an ERT so I set the ERC (via dips) as the first bird in the chain..and the bird with the sensor as the second (serial connection is coming from the ERC).
Tested this in Winbird...everything working great... full 6dof!
Tested the following in WorldViz... and I'm only getting position information (x,y,z)...no orientation (yaw,pitch, roll)
viz.add( 'tut_ground.wrl' )
PORT_FOB = 1
NUM_FOB = 2
ert = viz.add('flockofbirds.dls')
sensor = viz.add('flockofbirds.dls')
viz.link(sensor,viz.MainView)
Am I doing something wrong?
Thanks for any help!
Old 05-05-2008, 12:19 PM
What dip switch settings are you using?
Old 05-05-2008, 04:02 PM
ERC: 11100010
FOB: 11100100
Old 05-05-2008, 06:31 PM
I think your addresses might be need to be changed. Can you try the following dip switch settings (be sure to repower the device after changing it):
ERC: 11100001
FOB: 11100010
Old 05-06-2008, 03:27 PM
ERC: 11100001
FOB: 11100010
Dip switch 8 is for FLY/TEST mode.
(0/Off = Fly, 1/On = Test)
Doesn't correspond to the Bird Addressing...
Any other ideas?
Is there some way to test and see the orientation data that Vizard is getting from the bird?
Thanks again
Old 05-06-2008, 07:46 PM
My mistake, your original settings should be fine then. Not sure what the problem could be. We and other customers have successfully used the ERT with our plugin. I remember having a problem with it once though and we had to reset the device, which is different than repowering it. I forget what the reset procedure is, but if you know then you might want to try it out.
Other than linking the sensor to an object, you could manually retrieve and print the data. Example:
def printEuler():
    print sensor.getEuler()
vizact.onkeydown(' ',printEuler)
Flock of Birds recognized, but no data sent sjroorda Vizard 9 03-01-2016 08:48 PM
Flock of Birds question (again) Elittdogg Vizard 24 12-04-2007 09:37 AM
Flock of Birds Elittdogg Vizard 9 10-02-2007 01:53 PM
position tracking with patriot pgagolf Vizard 4 04-19-2007 04:42 AM
PPT vs. VPRN - Position Tracking not Working tmcw Precision Position Tracker (PPT) 21 02-27-2007 03:19 PM
