Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 02-07-2008, 02:30 PM
dudey12 dudey12 is offline
Send a message via MSN to dudey12
Vicon plug-in
I'm trying to use the vicon plug-in to access tracking data that vicon is spitting out.
I'm using the code provided in the example: simple.py
#Add a grounds
viz.add('tut_ground.wrl')
#The number of markers to connect to
NUM_MARKERS = 1
#Specify the IP address of the Vicon server. Default port is 800.
#If you wanted to specify port 803, you would do the following:
#PORT_VICON = '128.2.4.78:803'
PORT_VICON = '128.2.4.78'
#Add the specified number of markers
for x in range(NUM_MARKERS):
#Add a vicon marker
marker = viz.add('vicon.dls')
#Add a 3d ball to represent the marker
ball = viz.add('white_ball.wrl')
#Link the 3d ball to the marker
ball.link(marker)
#Move the viewpoint back 8 meters
viz.move(0,0,-8)
I'm finding that I'm only able to add two markers. The code works perfectly for two markers but if a third or fourth marker is added, I get an error message that says that the maximum number of markers has been reached.
Any help would be greatly appreciated!
Old 02-07-2008, 07:26 PM
The plugin allows you to add as many sensors as there are bodies. Are you sure that Vicon is sending out more than 2 bodies? The plugin should have no internal limit on the number of bodies to connect to.
Old 02-08-2008, 10:38 AM
- I am sure vicon is sending out 4 bodies as we have another program on the same machine that picks up all 4 markers. If it would help, I can post the exact code that we're using...
Old 02-14-2008, 01:32 PM
Here is the code that I'm using:
from datetime import datetime
#Add a grounds
#viz.add('tut_ground.wrl')
#PORT_VICON = '130.15.96.174'
PORT_VICON = '130.15.96.174:800'
viz.move(0,-2,-4)
VICON_MARKERS = 3
m1 = viz.add('vicon.dls')
b1 = viz.add('white_ball.wrl')
viz.link(m1,b1)
#print m1.getData()
m2 = viz.add('vicon.dls')
b2 = viz.add('white_ball.wrl')
viz.link(m2,b2)
#m3 = viz.add('vicon.dls')
#b3 = viz.add('white_ball.wrl')
#viz.link(m3,b3)
ANIMATE = 1
ANIMATE_RATE=0.1
def mytimer(num):
print datetime.now()
print m1.getPosition()
print m2.getPosition()
#print m3.getPosition()
viz.callback(viz.TIMER_EVENT, mytimer)
viz.starttimer(ANIMATE,ANIMATE_RATE,viz.FOREVER)
As mentioned previously, this code performs perfectly for two markers but complains when a third or fourth is added.
Old 02-27-2008, 10:39 AM
Sorry for the delay, we've been waiting to receive a simulator from Vicon. I believe the problem is that you are trying to retrieve marker data, where as the vicon plugin only outputs body data. I was able to simulate 17 bodies and connect to all of them through the Vizard plugin.
Now that we have a simulator for testing, we will be rewriting the Vicon plugin to support both marker and body data. This will be available in the next release.
Old 04-03-2008, 12:54 PM
Thanks a lot, this has been helpful for tracking the markers. We are, however, having a problem tracking bodies still. The vicon.getBodyList() works correctly, however when I try to use the vicon.getBody(val) function, I receive the error "_ViconExtension object has no attribute getBody". This occurs with the sample program in the help file, shown below. The IP address was changed to the correct one.
vicon = viz.add('vicon.dle',0,'192.168.0.114')
body = vicon.getBody(0)
marker = vicon.getMarker(0)
print body.getName()
print marker.getName()
Since the bodies are accessible from the getBodyList() function I tried linking a box to the body, but it didn't work either. Any suggestions?
Old 04-03-2008, 01:01 PM
Are you using the version of the Vicon plugin that came with the latest release? My guess is that you have some unofficial version. Please download the latest release and make sure you don't have an files called vicon.dle in your script directory.
Old 04-03-2008, 01:17 PM
I have downloaded the latest version of Vizard and am using the DLE. Mysteriously the getBody() function is working now, but its information does not update. The information updates properly when individual markers are linked to objects.
Vicon Plugin Micheal Plug-in development 2 08-29-2007 04:03 AM
