Old 04-08-2008, 09:20 AM
Mirror issues
I'm modifying my mirror to be able to use it in multiple experiments and I've run into a little problem. If you run the sample script in this post, you'll see that the mirrorquad doesn't reflect the lower part of the room properly. It seems that only if the quad is turned around it's Y-axis (the reflection works fine if you turn the quad around it's X and Z-axes), the reflection isn't correct anymore. Does someone know how to fix this?
def addMirror(mirror,mat=None):
	#If mirror matrix is not specifed, get matrix of mirror object
	if mat is None:
		mat = mirror.getMatrix()
	#Position of mirror
	pos = viz.Vector(mat.getPosition())
	#Direction mirror is pointing
	dir = viz.Vector(mat.getForward())
	dir.normalize()
	#Quaternion rotation of mirror
	quat = mat.getQuat()
	#Create render texture
	tex = viz.addRenderTexture()
	#Create render node for rendering reflection
	lens = viz.addRenderNode(size=[1024,1024])
	lens.attachTexture(tex)
	lens.setInheritView(True,viz.POST_MULT)
	lens.disable(viz.CULL_FACE,op=viz.OP_SET_OVERRIDE)
	#Setup reflection matrix
	rot = viz.Matrix.quat(quat)
	invRot = rot.inverse()
	lens.setMatrix(viz.Matrix.translate(pos*-1.0)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
	#Setup reflection clip plane
	plane = vizmat.Plane(pos=pos,normal=dir)
	dist = plane.distance([0,0,0])
	lens.clipPlane([-dir[0],-dir[1],-dir[2],dist+0.001])
	#Project reflection texture onto mirror
	mirror.texture(tex)
	mirror.texGen(viz.TEXGEN_PROJECT_EYE)
#Add gallery environment
#Use existing painting as mirror and specify the matrix
mirrorsurface = viz.addTexQuad()
mirrorsurface.setPosition([0, 1, 2.5]) #Y,Z,X
mirrorsurfacerotation = [0,90,0] #rotation around the Z,Y,X axes
mirrorsurface.rotate(mirrorsurfacerotation)
m = viz.Matrix()
m.setPosition(mirrorsurface.getPosition(viz.ABS_GLOBAL))
m.setEuler(mirrorsurfacerotation[0]-180,-mirrorsurfacerotation[1], mirrorsurfacerotation[2]) #Z,X,Y
#Apply mirror settings to mirror object
addMirror(mirrorsurface,m)
#Increase ambient lighting
viz.MainView.getHeadLight().ambient(1,1,1)
P.S. It can be the case that the order of the coordinates doesn't correspond to you coordinate-system. We also use dTrack software and therefore we had to adjust the coordinatesystem. Thanks to the comments you'll know which number represents which coordinate.
Old 04-08-2008, 11:25 AM
There is a bug in the clip plane calculation, replace that section with the following code:
s = -viz.sign(viz.Vector(dir) * viz.Vector(pos))
lens.clipPlane([-dir[0],-dir[1],-dir[2],s*dist+0.001])
Old 04-08-2008, 11:37 AM
Thanks for the quick reply! Replacing the section of the clip plane calculation did the trick. The mirror now works as it should work!
