Old 03-06-2008, 03:08 PM
JimB JimB is offline
tracker commands frequency over the
I have clustered 2 laptops and all is working well
except for the tracker. I am using an intersense cube and the master is
great but the client has too much latency . Is there any way I can change
this?
maybe reducing the tracker commands frequency over the
network???
Old 03-06-2008, 04:20 PM
Do you have the Synchronize frames option checked in your cluster master application? If so, the master and clients should be perfectly synced. If they are not, then the latency is probably caused by your LAN.
Old 03-07-2008, 08:57 AM
Sync fromes no difference
I tried the "sync frames" option but the latency on the client was the same. Additionally, I started to use a cross over cable instead of a network switch and that seemed to help. What else can we try?
Old 03-07-2008, 10:33 AM
Are you sure this is a latency issue? Is the client computer rendering everything smoothly, but with a delay? Or is the client computer rendering very choppy? Are you getting in error messages on the master or client computer?
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 12:31 PM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 03:38 PM
InertiaCube 2 commands vizmaster Vizard 2 09-26-2006 04:20 PM
looking for more info on avatar studio commands rosanna Vizard 1 03-26-2004 10:44 AM
Linking avatar 'bones' to a position tracker. zachhendershot Vizard 3 11-19-2003 10:26 PM
