Old 10-20-2007, 02:43 PM
Vinicius Lima Vinicius Lima is offline
Joystick Navigation
I am trying to use a joystick to navigate in interior spaces. So, I would like to be able to look up and down at the ceiling and floor and so far, my script is not doing that. I pasted the script I am using here and if I could get the information I am missing it would be great.
Thanks!
Vinicius
import vizjoy
#Add a ground model
viz.add('tut_ground.wrl')
#Add a joystick
joy = vizjoy.add()
def UpdateJoystick():
#Get the joystick position
x,y,z = joy.getPosition()
#Get the twist of the joystick
twist = joy.getTwist()
#Move the viewpoint forward/backward based on y-axis value
if abs(y) > 0.2: #Make sure value is above a certain threshold
viz.MainView.move(0,0,-y*0.1,viz.BODY_ORI)
#Move the viewpoint left/right based on x-axis value
if abs(x) > 0.2: #Make sure value is above a certain threshold
viz.MainView.move(x*0.1,0,0,viz.BODY_ORI)
#Turn the viewpoint left/right based on twist value
if abs(twist) > 0.2: #Make sure value is above a certain threshold
viz.MainView.rotate(0,1,0,twist,viz.BODY_ORI,viz.R ELATIVE_WORLD)
#UpdateJoystick every frame
vizact.ontimer(0,UpdateJoystick)
#Register a callback for joystick button events
def onjoybutton(e):
print 'Joystick button',e.button,'pressed'
viz.callback(vizjoy.BUTTONDOWN_EVENT,onjoybutton)
Old 10-22-2007, 11:50 AM
Can you please repost your script using the [code][/code] tags?
Old 10-22-2007, 01:08 PM
is that the way I'm supposed to do it?
import vizjoy
#Add a ground model
#Add a joystick
joy = vizjoy.add()
def onjoybutton(e):
Old 10-22-2007, 01:11 PM
No, you need to copy the code from Vizard then paste it into the form inside the code tags. The reason this is necessary is because it will preserve the original indentation of your code. Without the indentation, I cannot run your code.
Old 10-22-2007, 01:14 PM
I'm trying again.
import vizjoy
#Add a ground model
#Add a joystick
joy = vizjoy.add()
        viz.MainView.rotate(0,1,0,twist,viz.BODY_ORI,viz.RELATIVE_WORLD)
def onjoybutton(e):
Old 10-22-2007, 02:04 PM
I tried your script and the behavior I get is that moving the joystick forward/backward will move the viewpoint forward/backward. Moving the joystick left/right will move the viewpoint left/right. Turning the joystick will also turn the viewpoint. Is this not what you want? I don't understand what the problem is.
Old 10-23-2007, 10:39 AM
well, what I am trying to do is be able to navigate in a room and look up and down as well (at the ceiling and the floor). So far, with this script I haven't been able to.
Old 10-23-2007, 10:42 AM
You've programmed the script to move the viewpoint when the joystick is moved. If you want the viewpoint to look up/down when the joystick is moved, then use the viewpoint.rotate() command instead of the viewpoint.move() command.
