Old 08-17-2007, 07:09 AM
Joran Joran is offline
Send a message via Yahoo to Joran
Avatar animation
I am having some big problems with avatar animations. So here an example of something I can not get to work. I want an avatar, to fall dead, lay down for 2 seconds and then stand up again. Here my attempt:
man = viz.add('male.cfg')
def onKeyUp(key):
	if key == ' ':
		man.addAction(vizact.animation(7, freeze = True))
		man.addAction(vizact.waittime(2))
		man.addAction(vizact.animation(1))
viz.callback(viz.KEYUP_EVENT,onKeyUp)
And this doesn't work at all. How should I do it?
Greetings, Joran.
Old 08-17-2007, 10:44 AM
The following code should do what you want using the viztask module:
male = viz.add('male.cfg',pos=(0,0,6),euler=(180,0,0))
male.state(1)
import viztask
def execute():
	while True:
		#Execute animation with no delay out
		male.execute(7,delay_out=0.0)
		#Wait for animation to complete
		yield viztask.waitAnimationEnd(male,7)
		#Set animation state with no delay
		male.state(8,delay=0.0)
		#Restore standing pose after 1 second
		yield viztask.waitTime(2)
		male.state(1)
viztask.schedule( execute() )
If you prefer using actions, then the following code should work as well:
def onKeyUp(key):
	if key == ' ':
		man.addAction(vizact.animation(7,0,0))
		#Place avatar in laying state
		man.addAction(vizact.state_node(8,0.0))
		#Place avatar in standing state
		man.addAction(vizact.state_node(1))
