Old 02-13-2013, 12:15 PM
Ducky Ducky is offline
Avatar eye contact with user as it moves
I am looking at the sample WatchNode code. I removed the ball code and changed the nodeToLookAt in line 74 to viz.MainView. I also changed the avatar's state to (1). This makes the avatar's head follow me as I move around, which is the first thing I want. However, I seem to keep failing when I try to then make the avatar move/walkTo somewhere while still looking at me. I am missing something small here but that's b/c I am a newbie I am sure. Thanks for the help.
viz.setMultiSample(8)
viz.fov(60)
viz.go(viz.FULLSCREEN)
class WatchNodeAction(viz.ActionClass):
    """Makes avatar head follow node object around"""
    def begin(self,object):
        """Called once when action starts"""
        #Get the node the avatar should look at
        self.nodeToLookAt = self._actiondata_.data[0]
        #Get time the avatar will look at object
        self.duration = self._actiondata_.data[1]
        self.headBone = self._actiondata_.data[2]
        self.blendIn = self._actiondata_.data[3]
        self.timeElapsed = 0
        #Get the head bone and lock it
        self.head = object.getbone(self.headBone)
        self.head.lock()
        self.startQuat = self.head.getQuat()
    def update(self,elapsed,object):
        """Called every frame to update action"""
        self.timeElapsed += elapsed #time avatar has looked at node
        p = self.timeElapsed / self.blendIn
        #If looking for a finite duration, check if time has passed
        if self.duration > 0.0 and self.timeElapsed > self.duration:
            #duration passed, end action
            self.head.lookAt( self.nodeToLookAt.getPosition(), 0, viz.AVATAR_WORLD )
            self.end(object) #End the action and clear it from the action queue
        elif p < 1.0:
            #blend in head look
            targetQuat = self.head.getQuat()
            nextQuad = vizmat.slerp(self.startQuat,targetQuat,p)
            self.head.setQuat(nextQuad)
            #Done with blend in, just look at node
            self.head.lookAt(self.nodeToLookAt.getPosition(), 0, viz.AVATAR_WORLD)
    def end(self,object):
        if self.head:
            self.head.unlock()
        viz.ActionClass.end(self,object)
#Function to construct the action instance
def watchNode( nodeToLookAt, duration = viz.FOREVER, headBone = 'Bip01 Head', blendIn = .2 ):
    action = viz.ActionData()
    action.data = [ nodeToLookAt, duration, headBone, blendIn ]
    action.actionclass = WatchNodeAction
    return action
viz.MainView.setPosition( 0, 0, 0 )
male = viz.add( 'vcc_male.cfg' )
male.setPosition( 0, -1.5, 2 )
male.setEuler( 180, 0, 0 )
male.state(1)
#Apply the action to the avatar
male.addAction( watchNode(viz.MainView, viz.FOREVER) )
def endHeadWatch():
    #blend head to neutral orientation
    head = male.getBone('Bip01 Head')
    headQuat = head.getQuat(viz.AVATAR_LOCAL)
    male.endAction()
    head.lock()
    head.setQuat(headQuat, viz.AVATAR_LOCAL)
    male.addAction( vizact.headto( 0,0,0, 20, bone = 'Bip01 Head'), 1 )
vizact.onkeydown(' ',endHeadWatch)
Old 03-01-2013, 01:23 PM
Your code is not applying a walkto action to the avatar. Where/when do you want the avatar to walk?
Has user perception of avatar expressions been tested? Karla Vizard 3 10-28-2008 11:32 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 05:06 PM
