Old 01-10-2007, 09:59 PM
k_iwan k_iwan is offline
Exclamation Cluster Client Timeout after 10s...
We are getting "Failed to receive initialization commands from master" on client after 10 seconds. A scene with smaller content loads fine, but a scene with bigger content (which takes 10+ seconds to load) both clients give error as above.
We did try to use timeout settings in vizcore.cfg but it didn't solve the problem.
Any suggestions?
Kind Regards,
Iwan
Old 01-11-2007, 12:55 PM
Which timeout settings did you change? The relevant timeout for the error you are getting is viz.cluster.client.init_timeout. You should try setting this to a value greater than the time it takes to load your files. For example if it takes 20 seconds to load your files, I would set it to 40000.
Old 01-11-2007, 01:35 PM
Also, to be clear, you need to apply this setting on all the client computers, not the master computer.
Old 01-11-2007, 04:32 PM
Talking Solved!!!!!!!
Ah! I did not use "viz.cluster.client.init_timeout"... Problem solved!!! Thank you!!!
Kind Regards,
Iwan
Old 02-22-2007, 02:33 PM
hotspur1 hotspur1 is offline
What is the format for the vizcore.cfg file? I just tried to do something like this
viz.cluster.client.init_timeout 40000
but it says there is a syntax error. The help files don't seem to have an example....
Andy
Old 02-22-2007, 02:56 PM
The format is:
name = value
So your example would be:
viz.cluster.client.init_timeout = 40000
