Old 09-28-2016, 04:31 AM
rajnishv rajnishv is offline
Smile Creation of realistic water simulation
Hi Jeff,
I am creating a demo for a client,in which ,the environment has a shower from where the water will fall from up to down when the view point reaches below the shower in that proximity range.
I tried using basic effects,but no breakthrough.
Pls assist me how to proceed to get the realistic water simulation.
Pls see to the Video link which i need:
https://www.youtube.com/watch?v=SUzSLVqeIQs
Jeff,i have some questions.
1)Is there any code or effects or shaders or any concept in vizard,from which we can get the actual 3D realistic water simlulation.
2)Is there any software to make these actual 3D realistic water simlulation,that supports vizard(After exporting from the 3rd Party Software)
Waiting for your reply.
Thanx & Regards:
Mr.Rajnish Vishwakarma
Xenium Digital Pvt.Ltd,Mumbai
Old 09-28-2016, 01:25 PM
Hi Ranjish,
Vizard doesn't currently have a built in way to simulate water. While a shader could be written, I'd imagine it would need to be done from scratch. Jeff should be able to fill you in better on that.
The way we'd typically handle this from the art side is to use UV animation. Here's a recent example saved out in Max 2015 format. Let me know if you can't read it and need a different version:
http://forum.worldviz.com/showpost.p...58&postcount=6
Water rendering... help! k_iwan Vizard 13 04-04-2014 12:57 PM
Realistic gaze behavior of CCHD characters Frank Verberne Vizard 4 11-06-2013 01:07 AM
water simulation shahramy Vizard 0 10-15-2011 02:22 AM
Vizard water surface and fabrics? Darkmax Vizard 1 04-13-2010 04:39 PM
How to pause the Vizard simulation? 4711 Vizard 4 03-18-2010 05:45 PM
