Old 07-24-2016, 01:21 PM
Local coordinate and global coordinate
In the Vizard help, the coordinate is described like below.
Key Concepts
•By default, objects are added as children of the world and positioned in world coordinates.
•Each node has its own local coordinate system that moves with the node.
•A node's coordinate system has its origin at the node's center and axes aligned with the node's orientation.
I have a question, if one node with a local coordinate in pos [1,0,1], so if I apply a spin or moveto command, the object will transform on the base of [1,0,1]
what if I want the object spin or moveto on the base of pos [0,0,0], is there anything can do with it except for change the coordinate from the modeling software and add the object again to Vizard?
Old 07-24-2016, 08:02 PM
You could use the node.center command to change the point the objects rotates around. Or open the object in Inspector, translate the model, and then save it out again.
Old 07-24-2016, 08:21 PM
Ok Thanks a lot
Changing parent without changing absolute global position? The SundanceKid Vizard 2 05-23-2014 03:43 PM
A point in avatar's coordinate system omidbrb Vizard 2 05-15-2009 06:39 AM
Transforming coordinate systems. v-Salik Vizard 1 09-19-2007 08:45 PM
