Old 04-13-2016, 04:00 AM
Erikvdb Erikvdb is offline
Vizinfopanel automatic resize problem
Hi, I've ran into an issue with an infopanel in one of my projects. The default behavior of the infopanel is that it automatically resizes to the text or objects inside, which is fine for my application. However when I want to change one of the texts during the task, the panel doesn't automatically resize.
I've isolated the problem to this. The following code works, and the infobox is wrapped nicely around the new line.
import viz, vizinfo
ip = vizinfo.InfoPanel('', icon=False, align=viz.ALIGN_CENTER)
text = ip.addItem(viz.addText('hi'), fontSize=18, align=viz.ALIGN_CENTER_CENTER)
def setMessage():
	text.message('this is a looooooooong line')
setMessage()
But the following code, when pressing spacebar, the text changes but the infobox keeps it's original width, so the new text overflows.
import viz, vizinfo, vizact
def setMessage():
vizact.onkeydown(' ', setMessage)
I have a workaround where I just pad the original line with spaces to the length of the new line, so the infobox is always the same size (or I could do something like this), but maybe there's a different solution or maybe this is a bug that needs fixing
Old 04-13-2016, 12:36 PM
Thanks for the examples and good to know you already found workarounds. I will pass this along to the developers in case this is a bug.
Old 04-14-2016, 04:00 AM
The following code adds a line to mark the panel as dirty and recompute the layout. Does this work the way you would expect?
panel = ip.getPanel()
def setMessage():
	panel.dirtyLayout()
Old 04-14-2016, 06:11 PM
That works great, thanks!
Old 04-26-2016, 03:14 PM
JasmineJasmine JasmineJasmine is offline
I can resize the window but the screen resolution keeps stucks at a max of 1280x1024. The resolution of the host is 1600x900 or 1920x1200 (=external monitor).I'll try your suggestions and give feedback..
Old 04-27-2016, 03:31 AM
Sorry, I'm not quite following here. Are you referring to an issue within Windows or is this Vizard specific?
Cave Collision problem TopazFrost Vizard 2 02-13-2014 03:34 PM
The problem of adding two .ive models hengshan.li Vizard 1 08-08-2011 01:04 AM
Vizard problem mizutani_jun Vizard 4 01-09-2011 04:39 PM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 05:22 PM
