Old 02-04-2016, 07:52 AM
rawphl rawphl is offline
Standard Texture setup
How do you apply a standard texture setup (diffuse, normal, specular) to a model in vizard? I know GLSL so I could write a shader (although the vizard documentation is unclear on a lot of things, e.g. how is the uv attribute/varying called? Or is it using the old gl_TexCoord?)
but I'm sure this is already integrated.
Can I get a code example? I played around with vizfx.addMaterialEffect (which also isn't documented) but vizard would normally just use the diffuse texture and ignore the rest.
Thanks in advance.
Texture Coordinate Generation (TexGen) using Shader goro Vizard 1 05-31-2013 02:44 AM
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 01:48 AM
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
