Old 01-07-2016, 10:12 AM
blindberg blindberg is offline
pick intersect point in object coordinates
Is there a way to get the intersect point when picking using
viz.pick(info=True)
in the local coordinates of the object being picked?
Old 01-12-2016, 02:51 AM
The command returns a point in global coordinates but you could convert this into local coordinates of the object that is picked:
viz.addChild('piazza.osgb')
ball = viz.addChild('beachball.osgb',pos=[0,1.5,3])
def updatePick():
	info = viz.pick(info=True)
	if info.object == ball:
		print 'global',info.point
		helper = viz.addGroup(parent=ball)
		helper.setPosition(info.point, viz.ABS_GLOBAL)
		print 'local',helper.getPosition() #mode defaults to viz.ABS_PARENT
vizact.ontimer(1,updatePick)
viz intersect object point chris2307 Vizard 1 10-10-2014 02:31 PM
animate an object using 5dt data glove 5 ultra agrima Vizard 3 07-01-2014 11:17 AM
Find collision point of line and arbitrary object asdf Vizard 2 01-28-2013 10:04 AM
how to pick up the object, move and rotate using mouse nasr Vizard 5 05-05-2009 03:11 AM
Getting object position in screen coordinates v-Salik Vizard 1 10-19-2007 03:41 PM
