Old 11-24-2015, 03:27 AM
Seadna Seadna is offline
Question Hide Objects in a Model
Hi folks,
Hopefully you can help with this.
I am trying to hide parts of a model. I have a model file which is quite large and it has a lot of objects in it. Is it possible to hide some of these individually? I want to be able to press a key to hide certain objects.
I was thinking it could be somewhere along the line of this (but i am very new to Python):
import vizinput
ModelFile = 'model.ive'
def HideObject(CurObject):
	CurObject.disable(viz.RENDERING)
vizact.onkeydown('q', HideObject(ModelFile.Wall1))
Any help is much appreciated!
Old 11-30-2015, 05:08 PM
It's possible to hide sub-parts of a model. Here's an example:
piazza = viz.addChild('piazza.osgb')
vizact.onkeydown(' ',piazza.visible,viz.TOGGLE,'pz_ground-GEODE')
Old 12-10-2015, 06:32 AM
That's great Jeff thank you.
hide objects, model, python, sub nodes, visibility
artoolkit load 3d objects into application xcuddlex Vizard 8 04-18-2011 02:00 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Using hand model to grab objects without glove? cgibb Vizard 3 06-01-2009 06:43 PM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 12:04 PM
