Old 10-28-2014, 04:29 AM
pralka pralka is offline
3d models in vizard 5
I'm trying to use code written in vizard4 with vizard5. It's quite simple: contains walls, animations and two 3d models. Everything except models works fine.
Does anybody know why models (.dae) don't show up and how to fix it?
Many thanks in advance
Old 10-28-2014, 08:03 AM
Are you getting any error messages when loading the model?
If not, then it's most likely a scaling issue. The Vizard 5 Upgrade Guide mentions that Collada models will be automatically scaled to meters by default. You can disable this option by adding the following line to the beginning of your script, before any models are loaded:
viz.setOption('viz.model.apply_collada_scale', 0)
Try that and let us know if it doesn't solve the problem.
Old 06-18-2015, 11:49 PM
Hitesh Hitesh is offline
3d models
Hey Hi,
Where can i get free 3d models, I'm working on a project of developing virtual environment of a Mall. So where can i get 3d models related to that. Please suggest something.
Old 06-22-2015, 03:52 PM
The last section in the 3D models page has links to web repositories for 3D Models.
Blender .obj 3D models to Vizard 5 VirtuallyInsane Vizard 3 10-14-2014 12:36 AM
Higher Quality Models apanza Vizard 1 01-23-2012 11:21 AM
