Old 07-14-2014, 09:30 AM
fordprefect fordprefect is offline
Unhappy TickerDialog not showing
Servus,
I was in need of a number input option, ideally to be placed into menu. A progress bar was not precise enough for the range +/-50 and at least .5 precision. After trying a Textbox and fighting with input filtering I stumbled across the TickerDialog. Alas not possible to include it in the menu bar as it seems.
  • I'd very much like to see the TickerDialog functionality somehow added to the menu system.
Then I thought that it would not add too much clicking when I add it to a temporary panel. I tried the example with three dialogs on three different tabs of a TabPanel which works as it should. Though I want to be able to change e.g. all coordinates at the same time, so I tried a GridPanel. The size exceeds when adding TickerDialogs, but they ain't showing. Same with the normal panel. They won't show even if there is just one TickerDialog in use.
  • Please tell me where I go wrong
  • Or, if I'm not wrong, please fix it.
Thanks, Walter
21 is only half the truth.
gridpanel, menu, panel, tabpanel, tickerdialog
artoolkit no webcam showing vrmdl Vizard 3 03-10-2014 12:01 PM
Showing another program in a virtual world Frank Verberne Vizard 3 01-16-2013 11:26 AM
Models showing up Elizabeth S Vizard 9 09-06-2006 07:11 PM
V8 HMD showing snow pattern bailenson Vizard 3 06-22-2006 11:00 AM
running scripts without the IDE showing hotspur1 Vizard 7 10-30-2003 11:36 AM
