Old 06-26-2013, 01:40 AM
escmo escmo is offline
Can't retrieve data from ASL EyeTracker
Dear community,
I'm having issues retrieving data from an ASL EyeTracker. Everything works fine, uploading and calibration, until I try to get the data. After calibrating, I save the config as asl.xml in the same folder as the script supposed on [1], which raises an error when I try to run it:
ERROR: Failed to connect to ASL EyeTracker (Cannot create XML parser.
Please install MSXML4 from http://msdn.microsoft.com/XML/XMLDownloads)
ERROR: Failed to create extension sensor with asl.dle
MSXML4 is installed. Am I missing some import or did I forget something crucial?
Thanks very much, regards
[1] http://docs.worldviz.com/vizard/ASL_Eye_Tracker.htm
Old 06-29-2013, 03:05 PM
Is the ASL software running when you run the Vizard script. If so, try closing it down first.
data lose psykoko Vizard 3 12-16-2010 09:08 PM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 05:49 PM
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 06:17 PM
