Old 05-15-2013, 03:29 PM
Ryan Ryan is offline
Streaming data with onNetwork
I'm following the example shown here to get MatLab to stream data to Vizard:
http://docs.worldviz.com/vizard/Networking_Basics.htm
def onNetwork(e):
print '** Received message from',e.sender
print e.data #Prints: (5, 'hello', [1, 2, 3])
I know that I've successfully gotten some communication working, but when I run my MatLab program that sends the data, an error message appears in Vizard, instead of the data that I'm expecting. The error is:
File "file name", line 300, in onNetwork
print e.data
AttributeError: 'RawNetworkEvent' object has no attribute 'data'
I am able to transfer data from another Vizard script (using the other example from the Networking_Basics web site), so it seems that the problem has to do with streaming from other applications.
It seems there possibly is no e.data attribute when streaming information from other apps. Is there another way to address the information being sent other than e.data?
Thanks in advance.
Old 05-15-2013, 04:07 PM
When receiving data from a non-Vizard app, you can access the raw data using e.raw_data. The documentation mentions this. The raw_data attribute will be a string that contains the raw byte data from the UDP packet.
Old 05-16-2013, 07:47 AM
Thanks. Not sure how I missed that.
data, onnetwork, stream
data lose psykoko Vizard 3 12-16-2010 09:08 PM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 05:49 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 12:40 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 09:48 AM
