Old 03-19-2013, 02:28 PM
AndyGuatemala AndyGuatemala is offline
Rotate viewpoint while moving
So I'm trying to make a train simulation in which the viewpoint moves forward and rotates by itself once it is close to an object.
I am able to make it turn while moving forward when I'm pressing down a key however, I can not figure out how to make it rotate smoothly without using a key. When I try using the setEuler without pressing a key, it turns however, it is not smooth at all. Any ideas on how to make it turn smoothly on its own?
Old 03-20-2013, 02:41 AM
Create a spin action with the vizact.spinTo command and apply that to the viewpoint:
spinAction = vizact.spinTo(euler=[180,0,0], speed=30)
vizact.onkeydown(' ', viz.MainView.runAction, spinAction )
rotate, viewpoint
Rotate Viewpoint 360 Around Point/Object hotshotiguana Vizard 3 01-25-2012 06:36 PM
rotate around moving axis moneim230 Vizard 1 07-14-2010 10:04 AM
Moving main viewpoint when linked to PPT v-clizzin Precision Position Tracker (PPT) 1 04-20-2010 05:09 PM
viewpoint rotate bionic1 Vizard 1 01-27-2010 10:32 AM
moving viewpoint vs. translating Head_pos bailenson Vizard 5 02-01-2005 02:51 PM
