Old 02-12-2013, 04:52 PM
hzhao hzhao is offline
why the directional blur doesn't work well
Hi, I tried the directional blur But it doesn't work. The code is exactly copied from worldviz document.
import vizfx.postprocess
from vizfx.postprocess.blur import DirectionalBlurEffect
effect = DirectionalBlurEffect(angle=60, distance=40)
vizfx.postprocess.addEffect(effect)
The error message is :
ERROR: 0:9: '-' : wrong operand types no operation '-' exists that takes a left-hand operand of type 'uniform int' and a right operand of type 'const float' (or there is no acceptable conversion)
I tried different input number, eg, 60.0, 40.0, float and int. But it still doesn't work.
But the Gaussian blur works well. and the Zoom blur doesn't work either.
What is wrong?
Thanks!!
Old 02-13-2013, 08:15 AM
It sounds like the shaders for those effects are currently incompatible with your card/driver. What graphics card do you have?
Old 02-13-2013, 10:36 AM
it is Intel Q45/43 express chipset.
So it seems that I should try it with another computer.
Another question: is the blur effect only applied to window? or I can use the blur effect to an object anyway?
Old 02-15-2013, 09:46 AM
Thanks, we will look into adding support for Intel drivers to the effects.
The blur effects are applied to the entire output image of the window.
blur, post process
texbox overflow doesn't work when in panel disbeat Vizard 0 05-04-2011 04:24 AM
How to make blur vision? whj Vizard 2 07-16-2009 10:22 AM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 08:21 AM
Image blur jrodman Vizard 19 12-15-2006 03:48 PM
