Old 01-23-2013, 05:01 PM
Tractor beam module to inspect objects
Hacked a little code that moves selected objects close to the view, then puts them back.
To try, run the module, press and hold the spacebar, move the ball to an object, release the spacebar. Enjoy
import vizmat
import viztask
TRACTOR_TIME = 4
tractorNodes = []
def init(trackerNodeList):
	global startProjectSignal, tractorNodes
	tractorNodes = trackerNodeList
	startProjectSignal = viztask.Signal()
	viztask.schedule(think())
def startProject():
	global isProjectionDone
	startProjectSignal.send()
def stopProject():
	isProjectionDone = True
def think():
	cursor = viz.add('white_ball.wrl')
	cursor.color(viz.GREEN)
	cursor.alpha(.5)
	cursor.visible(viz.OFF)
	viz.startLayer(viz.LINES)
	viz.vertex([0,0,0])
	viz.vertex([0,0,0])
	lazer = viz.endLayer()
	lazer.color(viz.GREEN)
	lazer.visible(viz.OFF)
	while True:
#		print 'wait'
		yield startProjectSignal.wait()
		print 'start tractor'
		isProjectionDone = False
		cursor.visible(viz.ON)
		lazer.visible(viz.ON)
		hitObject = None
		while not isProjectionDone:
			line = viz.MainWindow.screenToWorld([.5, .5])
			line.length = 100
			lazerStart = line.begin
			lazerStart[1] -= .1
			lazer.setVertex(0, lazerStart)
			lazer.setVertex(1, line.end)
			intersectObj = viz.phys.intersectLine(line.begin, line.end)
			if intersectObj.valid:
				cursor.setPosition(intersectObj.point)
				if intersectObj.object in tractorNodes:
					hitObject = intersectObj.object
					hitObject = None
			yield None
#		print 'done'
		if hitObject:
			#start Tractor
			startTime = viz.tick()
			startPos = hitObject.getPosition(viz.ABS_GLOBAL)
			bb = hitObject.getBoundingBox(viz.ABS_GLOBAL)
			distanceFromView = max(bb.width, bb.height, bb.depth) * 2
			centerOffset = vizmat.Vector(startPos)- vizmat.Vector(bb.center)
				percentageToGo = (viz.tick()-startTime) / TRACTOR_TIME
				if percentageToGo > 1.0:
					break
				line.length = distanceFromView
				targetPos = line.end + centerOffset
				pos = vizmat.Interpolate(hitObject.getPosition(viz.ABS_GLOBAL), targetPos, percentageToGo)
				hitObject.setPosition(pos, viz.ABS_GLOBAL)
				yield None
			hitObject.runAction( vizact.moveTo(startPos, time=TRACTOR_TIME*.2) )
if __name__ == "__main__":
	viz.phys.enable()
	room = viz.add('gallery.osgb')
	room.collideMesh()
	list = []
	for i in range(5):
		b = viz.add('box.wrl', pos=[i*.5, 1.5, 2], scale=[.3]*3)
		b.collideMesh()
		list.append(b)
	h = viz.add('tut_hedra.wrl', pos=[-1, 1, 4])
	h.collideMesh()
	list.append( h )
	h = viz.add('vcc_female.cfg', pos=[-2, 1, 4])
	h.collideMesh()
	list.append( h )
	h = viz.add('ball.wrl', pos=[-2, 1, 4])
	h.collideMesh()
	list.append( h )
	init(list)
	vizact.onkeydown(' ', startProject)
	vizact.onkeyup(' ', stopProject)
Paul Elliott
WorldViz LLC
Exception in module vizjoy fordprefect Vizard 2 12-03-2012 02:41 AM
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
static or dynamic objects shahramy Vizard 2 11-10-2010 01:32 AM
