Old 12-17-2012, 11:48 AM
kparkins kparkins is offline
ppt-x plugin returned zero or less cameras, 0
I tested our WorldViz setup recently (PPT-x 3.14.5512) and had a healthy system that could track our space along with head orientation from an intersense inertiacube2. When I launched PPT-X today, the first thing it did was to ask for the serial numbers for the camera. The serial number text entry box was on top of a button which was inadvertently activated. When the program finished initializing, it said that it could not find any cameras and that the null plugin would be used instead. When I try to load the ppt-x plugin, the same thing happens, it scans for a second and then says no cameras found.
No problem, I thought, I had old configs so I copied that over the cfg file that was generated from the above session. The same thing ended up happening, no cameras. I double checked the serial numbers, and they were all correct in the cfg file:
I opened the transformer box to make sure that the fuses were okay and that the cameras were connected to the Matrox board. Everything looked good.
I then connected the cameras to an external monitor to make sure a signal was coming through the BNC connections. The cameras are all working.
Still though, the PPT-X program is not able to see the cameras.
I opened the Matrox utility to make sure that the board is working. I dumped the System Info and it showed a Matrox Morphis card. I can't get an image with Intellicam though.
At this point I'm stuck. It seems like an issue with the Matrox board, but I am uncertain on how to debug it. When I pull up the DCF file for the Morphis board, it only shows 1 tap and 1 camera, but maybe that's how it's supposed to be. I don't know.
Any suggestions?
Old 12-17-2012, 12:52 PM
First thing to try is re-installing the Matrox drivers. Please contact support@worldviz.com and we'll help with that.
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Multiple Cameras for AR artoolkit plugin Pho46 Vizard 3 11-10-2010 06:59 PM
PPT cameras not connected sisun1030 Precision Position Tracker (PPT) 0 03-05-2010 08:02 AM
PPT Studio - 3 of 4 Cameras not working sisun1030 Precision Position Tracker (PPT) 1 01-05-2010 02:29 PM
