Old 04-10-2012, 05:12 PM
surf3rguy surf3rguy is offline
To Masaki regarding render nodes
I am trying to render a virtual environment on a render node that is located within another virtual environment. Both worlds need to run simultaneously, one on the render node, and the other on containing the render node. How is this task accomplished?
Old 04-17-2012, 05:37 PM
masaki masaki is offline
Here is some sample code to get you started. This will create two different environments (scenes). One has the piazza and one has the dojo. The rendernode will render the dojo scene within the piazza scene.
#add a world
world1 = viz.add('piazza.osgb')
#add a second scene
scene2 = viz.addScene()
#add a second world and set to it the second scene
world2 = viz.add('dojo.osgb', viz.WORLD, 2)
#add a render node
renderNode = viz.addRenderNode( )
#set the scene of the render node to 2
renderNode.setScene(2)
#add a render texture at 512x512 resolution
renderTexture = viz.addRenderTexture(size=[512,512])
#attach the rendertexture
renderNode.attachTexture( renderTexture)
#add a texture quad
quad = viz.addTexQuad()
#add the rendertexture to the texturequad
quad.texture( renderTexture )
#position the texture quad
quad.setPosition(0,1,0)
viz.MainView.setPosition(0,1.8,-3)
Masaki
re: render nodes and scenes nige777 Vizard 2 10-18-2010 01:14 PM
Internal nodes of loaded model files? dtidrow Vizard 2 05-12-2009 08:55 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 04:27 PM
