Old 03-20-2012, 06:52 AM
mhead10 mhead10 is offline
Failed to load jpeg
I'm trying to simply import a .jpeg and then .wrl file from solidworks, however I've not been successful with either.
I saved an arbitrary jpeg (lake.jpeg) in the same folder as my python program (cube_test). I run the test script with the following code to import the picture:
background=viz.addChild('lake.jpeg')
I've also tried 'lake.jpg', as well as trying a .wrl file from solidworks. However, I alway get and error, like the following:
ERROR: Failed to load 'lake.jpeg'
Any thoughts on what I'm doing wrong?
Thanks ahead of time for any help!
Old 03-20-2012, 07:20 AM
To load an image, use the viz.addTexture command instead of viz.addChild:
texture = viz.addTexture('lake.jpg')
Old 03-20-2012, 11:53 AM
Thank you for your help! I knew it was something silly!
artoolkit load 3d objects into application xcuddlex Vizard 8 04-18-2011 02:00 AM
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 05:16 AM
Failed to load wav file BrynJ Vizard 1 04-24-2008 09:35 AM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 12:51 PM
