Old 01-24-2012, 05:33 AM
dpamplona dpamplona is offline
Main window size larger than monitor
Hi!
I would like to set the Main window size larger that the monitor resolution in full screen (like a virtual desktop).
For that, I thought I should use the command:
viz.window.getFullscreenRectangle([x,y, w,h])
However when I write:
import viz,math
viz.window.setFullscreenRectangle([0, 0, 2024, 2024])
I got the attribute Error:
AttributeError: '_WindowInterface' object has no attribute 'setFullscreenRectangle'
However if I type:
import viz,math
if viz.window.getFullscreen():
print 'fullscreen'
print 'window
it gives the correct output 'fullscreen'
This is wired, because both of them are part of the same module viz:window.
Can anybody explain to me what is going on? What should I correct? And even more, is setFullScreenRectangle the command that I should use?
monitor resolution, setfullscreenrectangle, window size
3D stereo on a secondary monitor (projected wall) michaelrepucci Vizard 1 07-29-2008 12:25 PM
Monitor Modes & Vizard (problems...) tmcw Vizard 1 10-03-2007 08:29 AM
Viewpoints outside the main window sjroorda Vizard 7 11-03-2005 07:11 AM
