Old 01-18-2012, 12:19 PM
PickRect code snippet
Example of window.pickRect that I though could be handy for other folks out in vizland:
model = viz.add("mini.osg")
viz.MainView.setPosition([0, 1.2, -5])
viz.mouse.setOverride(viz.ON)
vizact.onkeydown(' ', viz.mouse.setOverride, viz.TOGGLE)
print model.getNodeNames()
parts = []
for name in model.getNodeNames():
    part = model.getChild(name)
    part.nodeName = name
    parts.append(part)
#Rectangle Pick
viz.startLayer(viz.LINE_LOOP)
viz.vertex([0, 0, 0])
box = viz.endLayer(parent=viz.SCREEN)
box.alpha(.8)
firstPoint = [0,0]
def startPickRect():
    global firstPoint
    firstPoint = viz.mouse.getPosition()
    box.setVertex(0, firstPoint+[0])
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, startPickRect)
def updateBoxVisual():
    if viz.mouse.getState() & viz. MOUSEBUTTON_LEFT:
        mouseScreenPos = viz.mouse.getPosition()
        box.setVertex(1, [mouseScreenPos[0],firstPoint[1],0])
        box.setVertex(2, mouseScreenPos+[0])
        box.setVertex(3, [firstPoint[0],mouseScreenPos[1],0])
vizact.onupdate(viz.PRIORITY_DEFAULT, updateBoxVisual)
def endPickRect():
    #update box visual
    rect = firstPoint + mouseScreenPos
    # Get all nodes within the rectangle
    picked = viz.MainWindow.pickRect(rect)
    for node in picked:
        print node.nodeName
vizact.onmouseup(viz.MOUSEBUTTON_LEFT, endPickRect)
Paul Elliott
WorldViz LLC
Using Sphinx to generate code documents nabrahamson Vizard 0 10-31-2011 08:38 AM
Suggestion: Code Browser kopper Vizard 5 05-23-2011 04:39 AM
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 10:56 PM
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 03:58 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 05:30 PM
