Old 05-19-2011, 02:59 PM
jsnider jsnider is offline
parallel port on laptop
We want to use vizparallel to send pulses on a laptop parallel port connected with a pci express external card (viz 3.0, win7 64-bit, startech ec1pecps). I can't get it to recognize the address and was wondering if anyone has managed to get one to work?
Best,
Joe
Old 05-20-2011, 11:30 AM
Make sure you have full administrator rights on that machine. Being logged in as admin is not always enough. You must also launch Vizard with "Run as admin" method and then run the target script using the parallel port. "Run as admin" done once should be enough and not then required on subsequent executions.
Running as admin should not be necessary for Vizard 4
Old 05-20-2011, 04:41 PM
Running as admin didn't seem to help. I haven't tried Vizard4.
If anyone is interested, I solved the problem (at least temporarily) but switching to 32bit win7 and using a wrapper around the free TVickPort. It looked possible for win7-64, but I couldn't get it to work.
Best,
Joe
Question about serial port mizutani_jun Plug-in development 6 11-21-2010 03:53 PM
Biopac Parallel Port Writer Error: missing INPOUT32.dll mmatlock Vizard 1 06-30-2010 02:04 PM
parallel port method bionic1 Vizard 2 05-04-2009 06:41 PM
Best TV out for laptop Matt Wheeler Vizard 0 11-10-2008 07:52 PM
USB port monitoring wolbers Vizard 1 11-20-2007 09:24 AM
