Old 02-15-2011, 12:58 AM
Albert Russel Albert Russel is offline
Mouse pointer problem
In one of my programs I want a DropList to appear during a run and choose an item and then hide the list and the mouse pointer again. It all works fine except that the mouse will not go away until I move it after I disabled it. I tried viz.sendEvent(viz.MOUSE_MOVE_EVENT) to simulate a mouse movement but the pointer only disappears after a real mouse movement. Is it possible to hide the mouse without physically moving it?
Thanks in advance, Albert
import vizshape
vizshape.addGrid()
viz.clearcolor(viz.GRAY)
def enableMouse():
      viz.mouse(viz.ON)
      viz.cursor(viz.ON)
      viz.mouse.setVisible(viz.ON)
def disableMouse():
      viz.mouse(viz.OFF)
      viz.cursor(viz.OFF)
      viz.mouse.setVisible(viz.OFF)
drop = viz.addDropList()
drop.setPosition(0.5, 0.5)
drop.addItems(["a", "b", "c"])
drop.visible(viz.OFF)
disableMouse()
def handleKey(key):
	global drop
	if key == 'x':
		drop.visible(viz.ON)
		enableMouse()
	elif key == 'y':
		disableMouse()
		viz.sendEvent(viz.MOUSE_MOVE_EVENT) # does not work, I must move the real mouse to make the pointer go away
viz.callback(viz.KEYBOARD_EVENT, handleKey)
Old 02-18-2011, 11:22 PM
hosier hosier is offline
I ran into a similar issue a few years ago. What I came up with is show below. I found this function that acts as if the mouse has been moved and the left button clicked.
from ctypes import *
import time, win32con, win32gui
PUL = POINTER(c_ulong)
class KeyBdInput(Structure):
    _fields_ = [("wVk", c_ushort),
    ("wScan", c_ushort),
    ("dwFlags", c_ulong),
    ("time", c_ulong),
    ("dwExtraInfo", PUL)]
class HardwareInput(Structure):
    _fields_ = [("uMsg", c_ulong),
    ("wParamL", c_short),
    ("wParamH", c_ushort)]
class MouseInput(Structure):
    _fields_ = [("dx", c_long),
    ("dy", c_long),
    ("mouseData", c_ulong),
    ("time",c_ulong),
class Input_I(Union):
    _fields_ = [("ki", KeyBdInput),
    ("mi", MouseInput),
    ("hi", HardwareInput)]
class Input(Structure):
    _fields_ = [("type", c_ulong),
    ("ii", Input_I)]
class POINT(Structure):
    _fields_ = [("x", c_ulong),
    ("y", c_ulong)]
def click(x,y):
    orig = POINT()
    windll.user32.GetCursorPos(byref(orig))
    windll.user32.SetCursorPos(x,y)
    FInputs = Input * 2
    extra = c_ulong(0)
    ii_ = Input_I()
    ii_.mi = MouseInput( 0, 0, 0, 2, 0, pointer(extra) )
    ii2_ = Input_I()
    ii2_.mi = MouseInput( 0, 0, 0, 4, 0, pointer(extra) )
    x = FInputs( ( 0, ii_ ), ( 0, ii2_ ) )
    windll.user32.SendInput(2, pointer(x), sizeof(x[0]))
    return orig.x, orig.y
You can then call the function like:
click(1,1)
and it's like you clicked it at the location x=1,y=1.
For me, the mouse click was actually more important than moving the mouse, so I ended up modifying the the code so that instead of moving the mouse to the passed x and y, I just kept it at the same point and performed the mouse click.
Aaron
Old 02-21-2011, 01:10 AM
Thanks Aaron, windll.user32.SetCursorPos(x,y) solved my problem.
viz.STEREO mouse problem moneim230 Vizard 0 12-05-2010 12:32 AM
mouse pointer shahramy Vizard 3 09-07-2010 02:22 PM
Laser Pointer Question (Again) Elittdogg Vizard 5 09-08-2009 12:02 PM
how to make the mouse pointer pain... yak Vizard 0 05-30-2009 07:05 PM
Mouse problem steve Vizard 7 07-14-2005 03:01 PM
