Old 01-28-2011, 06:59 AM
jincheker jincheker is offline
Why I need two points for viz.startlayer(viz.POINTS)
Hi, I want to show the points as mouse moves, and I program like below:
def plotGraph(x,y):
	viz.pointsize(5)
#	viz.vertexcolor(viz.RED)
#	viz.vertex(0,0,0)
	viz.vertexcolor(viz.BLACK)
	viz.vertex(x,y,0)
	line = viz.endlayer(viz.SCREEN)
	print 'plot',x,y
def onMouseMove(e):
	plotGraph(e.x,e.y)
viz.clearcolor(viz.SKYBLUE)
viz.callback(viz.MOUSE_MOVE_EVENT,onMouseMove)
The problem is if i comment
viz.vertex(0,0,0)
The code won't work, but if I uncomment them, then it works.
Can anyone tell me why? Is it because startlayer needs at lease two points?
Thank you
Old 01-28-2011, 08:46 AM
OpenSceneGraph will cull objects that appear very small on screen. Since you have one point, it is computed as infinitely small on screen and not rendered. You can disable viz.CULLING on the node to prevent this from happening:
line.disable(viz.CULLING)
Support for Natural Point's Optitrack system bennovdbogaard Vizard 14 10-25-2012 06:22 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 11:22 AM
on the fly points John P Vizard 1 07-15-2009 05:22 PM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 04:42 AM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 02:50 PM
