Old 11-28-2010, 07:04 PM
jassel41 jassel41 is offline
Adding Objects to all Scenes
Is there a way to add an object to all scenes?
What I want to do is set up a menu scenario which is appended to the screen but want it in every scene. For now, I have it set up where the code is duplicated for scene 1 and scene 2 and the objects are added to their respective scenes, but the objects are exactly the same and I need it for around 4 scenes. Is there a way to make it so an object gets added to every scene?
Thank you,
Jassel41
Old 11-29-2010, 02:35 AM
TarkaDahl TarkaDahl is offline
hi jassel41
Could you use the clone command to clone the menu objects to the other scenes.
i dont know if this will work but might be worth a try.
static or dynamic objects shahramy Vizard 2 11-10-2010 12:32 AM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 12:04 PM
adding new objects gina Vizard 4 11-29-2006 11:01 AM
