Old 03-15-2005, 10:40 AM
Johannes Johannes is offline
Delay without viz.waittime?
how do I put a delay inside my skript?
without viz.waittime which stalls the whole scene.
I want a projector screen to move down bevor graphs get put on it.
If I do:
screenWall.goto(0,-2.2,0, .8)
putGraphOnScreenWall()
the graphs are on the ScreenWall before it is down...
Thank you,
Johannes
Old 03-15-2005, 12:11 PM
You will need to use a callback for this. The following callback is called every time a built-in animation finishes. Check when the screen has finished moving then call your function:
def onactionend(object,action,pool):
	if object == screenWall and action == viz.MOVE:
viz.callback(viz.ACTION_END_EVENT,onactionend)
Old 03-16-2005, 09:59 AM
Thank you.
It works 90 % fine.
When the user klicks on the graphOnWall Checkbox again, before the projection-surface is completely up, the graphs get put in the air.
I guess that is because while the projection-Surface is moved up and the user clicks the checkbox the movement is stopped => ACTION_END_EVENT is triggered, checkbox is ON and so the graphs get put in the air.
To solve this I would need to check, if the ACTION_END_EVENT occured after the surface moved down vs. up.
Sorry, solved it while writing this:
if checkboxWall.get()==1 and screenWall.get(viz.POSITION)[1]==0:
