Old 03-01-2011, 02:34 PM
fivel_lab fivel_lab is offline
physics problem
hey, first time poster here
currently, i'm trying to setup a balance board type apparatus that includes the board, and a ball that rests on the center. the board tilts up and down and is controlled by a wii remote controller. as the board tilts, the ball rolls down accordingly. all that is working fine and dandy, but a problem keeps occuring where the ball suddenly drops through the board, and i haven't been able to figure out why. i've tried playing with the density, bounce, and hardness of both the board and the ball, but still no luck.
here's my script so far:
#create balance board
bar = vizshape.addBox(size=(20, 1,1))
bar.setPosition([0,2,5])
bar.color(1,0,0)
barCollideShape = bar.collideMesh()
#create ball
ball = viz.add('ball.wrl')
ball.setScale([1.5,1.5,1.5])
ball.setPosition([0, 7, 5])
ballCollideShape = ball.collideSphere()
as well as the scrip for the wii remote controls:
#Add wiimote extension
wii = viz.add('wiimote.dle')
#Connect to first available wiimote
w = wii.addWiimote()
def updateWiiMote():
	w.led = wii.LED_1 | wii.LED_4
	x,y,z = w.getAccel()
	x,y,z = threshIt(x,y,z)
	newEuler = (0,0,-x*10)
	print newEuler
	bar.setEuler(newEuler)
#poll joystick continuously
vizact.ontimer(0, updateWiiMote)
and i also created "guardrails" in front of and behind the balance board, to keep the ball from rolling off on the z-axis:
#create rear guiderail
farGuiderail = vizshape.addBox([30, 50, .01])
farGuiderail.setPosition([0,2,5.5])
farGuiderailMesh = farGuiderail.collideMesh()
farGuiderail.disable(viz.RENDERING)
farGuiderail.disable(viz.DEPTH_WRITE)
#creat front guiderail
nearGuiderail = vizshape.addBox([30, 50, .01])
nearGuiderail.setPosition([0,2,4.5])
nearGuiderailMesh = nearGuiderail.collideMesh()
nearGuiderail.disable(viz.RENDERING)
nearGuiderail.disable(viz.DEPTH_WRITE)
any help would be greatly appreciated. thanks in advance
Old 03-01-2011, 05:28 PM
Try using a collideBox for the bar. Does that work?
barCollideShape = bar.collideBox()
bar.disable(viz.DYNAMICS)
The bar's collideMesh has no thickness to it. If the ball is moving fast and the physics engine does not detect the collision between the ball and bar one frame the ball will fall through.
Old 03-01-2011, 07:31 PM
I tried the collide box but abandoned it because it made the balance board fall to the ground. I guess i could try using a fulcrum to support the board...
Old 03-02-2011, 10:20 AM
will prevent forces like gravity from affecting the bar.
Old 03-02-2011, 03:34 PM
thanks, but i'm still having the same problem. the ball passes through the balance board quite easily...
Old 03-03-2011, 04:13 PM
In order to get the bar and the ball to collide correctly you'll need to move the bar by applying a force or torque to it:
viz.phys.enable()
bar = viz.add('box.wrl')  # Add a box
bar.setScale(20,1,1) # Make it look more door like
shape = bar.collideBox() # Enable physics on the box
shape.setDensity(0.1)
ball.setPosition([0, 2, 0])
joint = viz.phys.addHingeJoint(bar,None,pos=[0,0,0],axis0=[0,0,1]) # Hinge joint attached to world
def push():
    bar.applyTorque([0,0,20],duration=0.2)
vizact.onkeydown('1',push)
def pushBack():
    bar.applyTorque([0,0,-20],duration=0.2)
vizact.onkeydown('2',pushBack)
def resetSimulation():
    if ball.getPosition()[1] < -5:
        ball.reset()
        bar.reset()
        bar.setEuler([0,0,0])
vizact.ontimer(1,resetSimulation)
import vizcam
vizcam.PivotNavigate(center=[0,0,0],distance=30)
Old 03-04-2011, 11:23 AM
i'm going to give this a try.
i was originally having the bar via the wiimote. so as the wiimote moved, the euler of the bar moved accordingly. could that be the reason, or at least one of the reasons why the ball kept falling through?
Old 03-04-2011, 02:02 PM
To make sure the physics engine calculates the collisions correctly you should apply a force or torque to the bar rather than manually setting it's orientation using the setEuler command. You can still use the wiimote data to decide what torque to apply.
Old 03-07-2011, 07:53 PM
it works
thanks so much for all your help, much appreciated!
Vizard problem mizutani_jun Vizard 4 01-09-2011 03:39 PM
Physics Problem Sandro Holzer Vizard 4 03-29-2009 10:51 PM
physics engine exception ad_astra Vizard 3 03-25-2009 11:31 AM
picking problem... k_iwan Vizard 2 07-27-2007 07:57 PM
