Old 05-04-2010, 11:43 AM
shahramy shahramy is offline
Unhappy how to change shadow direction?
i used Shadow module to create shadow but I cant change the direction of shadow in the other hand the point in which the imaginary light source exists. i have used this code.
SHADOW_RES = 2048
#Postion of shadow projector
SHADOW_POS = [-30.800,5.000,50 ]
SHADOW_AREA = [150,150]
#Create shadow projector
shadow = Shadow.ShadowProjector(size=SHADOW_RES,pos=SHADOW_ POS,area=SHADOW_AREA)
#Add avatar as a shadow caster
shadow.addCaster(obj1)
shadow.addCaster(obj2)
#Add ground as shadow receiver
shadow.addReceiver(sh)
with this shadow_pos the shadow will create exact under the two object which have many distance from each other!!!
setEuler method of Shadow module omidbrb Vizard 1 02-22-2010 10:35 AM
Change Viewpoint in different scenes lilio Vizard 1 08-28-2009 03:56 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 01:50 AM
