Old 03-05-2010, 07:20 AM
VelvetElvis VelvetElvis is offline
Jpeg Image issue?
It seems whenever I export from my file that has jpeg texture images, the jpegs are inherently destroyed by the export process. Either I get a neat-o rainbow dots effect over everything, or the jpegs are completely black. No matter what compression I use, if I use original images or have the OSG exporter deal with them, nothing works.
To get around this, I'm not even dealing with exporting the images and just using the real originals in the folder.
However, if I use targa's as input or have the OSG export convert the jpegs to targa's or png's the images export just fine. Now, I realize jpeg image format is a new thing and not widely used these days, but this seems to be a bug and it is seemingly only related to jpegs.
Cal3D texture issue from Max shivanangel Vizard 5 10-17-2008 01:17 PM
screen image erchrastil Vizard 8 06-27-2008 12:45 PM
View an image on the Fakespace HMD roman_suvorov Vizard 16 05-23-2008 08:51 AM
Only part of tiled image vizmaster Vizard 5 09-11-2006 01:11 PM
