Old 03-24-2010, 12:31 AM
billjarrold billjarrold is offline
too large string for <viz>.input
I have this command...
dob = viz.input("Please enter the subject's date of birth in yyyy-mm-dd format (e.g. Jan 2, 2003 would be 2003-01-02):")
...in my program. It is too big for the little input window to display. It just truncates after somewheres around the word "format" or thereabouts.
Any ideas what I should do? (Hopefully you're not going to say 'Make your input string shorter.') e.g. is there some secret parameter for making the input widget bigger?
Bill
Old 03-24-2010, 05:02 PM
The size of the message is fixed. Using a vizinfo box you could create longer messages.
String within a string problem? Elittdogg Vizard 1 08-29-2008 01:35 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 05:19 PM
Looping over large number of images MrSmiley009 Vizard 3 02-28-2006 04:08 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 03:23 PM
Getting the String of a Text3d Object vjosh Vizard 1 01-03-2005 11:37 PM
