Old 02-08-2010, 05:46 AM
dwaik dwaik is offline
adding texture to each sub object
hello...
i want to make use of multi-layered texturing in vizard, i tried it on a single object that contains a single mesh, it works.
the problem now is that i have an obj file contains a number of meshes, each has it texture, and i want to add a new textuer layer for each mesh..
how can i get the meshes in my obj suppose its name "palace".
thank you in advance
Old 02-08-2010, 12:28 PM
When applying a texture to an object, you can optionally specify the name of the sub-node you want it to be applied to. If your model contains a sub-node named palace then you can apply a texture to it using the following sample code:
# Apply texture to first unit
model.texture(tex1,node='palace')
# Apply texture to second unit
model.texture(tex2,node='palace',unit=1)
Old 02-09-2010, 01:05 AM
to be clear i have a 3DS file contains a group named advArabianCastle_G and it has 300+ children meshes (one of them called "frontDoor") each with its own texure, for each mesh i want to add another texture from within vizard.
and i have imported the file and called it palace in vizard.
can you help me getting the child node name, or adding the texture to "frontDoor"?
*hint i used the palace.getChildren() and it returned nothing
Applying texture or colour to an on-the-fly object tomo_the_third Vizard 1 06-22-2009 11:12 AM
Move texture from one object to another Johannes Vizard 2 02-09-2005 03:55 PM
