Old 10-22-2004, 12:06 PM
kim_swinth kim_swinth is offline
Question about 3DMeNow
What versions of 3DMeNow are compatible with PeopleMaker & Vizard? I have been using 3DMeNow Professional 1.0.45, but for a current project, I am thinking of trying a newer version (I forget the version we have, but I think it's 1.5) that has more facial morphs available. Before I spend time making new heads, however, I wanted to make sure they would work with Vizard.
Kim
Old 10-22-2004, 12:44 PM
tobin tobin is offline
PeopleMaker and Vizard are 100% blind to what version of 3DMeNow you might use.
Any 3D model that is in a standard file format that Vizard can load can also be loaded into PeopleMaker. Once in PeopleMaker, that object can be exported as a VZF. While PeopleMaker is used mainly for building faces, it can be any generic object for morphing purposes. Only those objects with "neck" vertices identified can subsequently be attached to an avatar's body.
Old 10-22-2004, 01:53 PM
Great ! Thanks
