Old 09-09-2009, 08:07 AM
vijaykiran vijaykiran is offline
OSG version number in Vizard 3.0
Does anyone know what version of OSG does Vizard 3.0 use?
I am trying to load an .ive file converted from 3DS using OSG 2.8 and Vizard complains that the .ive file is new and is not supported by Vizard.
Vijay.
Old 09-09-2009, 12:03 PM
Vizard 3.0 uses OSG 1.2. This means IVE files generated using newer versions of OSG will not load in Vizard 3.0, since IVE is a binary format. However, the OSG format should be backward compatible with older versions of OSG.
Problems with newest version of Vizard mjabon Vizard 6 07-29-2008 10:51 AM
Next version of Vizard bailenson Vizard 1 08-04-2004 05:45 PM
number of faces to load using the 'old' txt version of avatars bailenson Vizard 1 06-06-2004 12:30 PM
