Old 06-10-2009, 10:11 AM
GiudiceLab GiudiceLab is offline
HRTF clarification question
We are using spatialized audio in our lab and we are trying to understand how the HRTF is implemented. That is, we know that we can set an audio option for 'HRTF_Full' or 'HRTF_Lite', but we are unclear about what is actually happening. Are we only affecting the DirectX settings? Does Vizard do any additional processing?
Specifically, we are trying to understand how or if the virtual room interacts with the audio virtualization functions, and to what extent we can control these properties in Vizard.
Old 06-15-2009, 04:40 PM
Thanks for the post. Someone here will get back to you on this.
Old 06-15-2009, 10:21 PM
Vizard simply wraps the DirectSound API. So Vizard does not do any additional proccessing.
So the nature of the room 3D model does not affect the 3D sound that occurs in it. Only the sound-source's/listener's position and orientation factor into the 3D sound algorithm.
From the DirectSound API documentation, the 'HRTF_Full' or 'HRTF_Lite' options allow you to trade the quality of the 3D sound effect with CPU cost.
http://msdn.microsoft.com/en-us/libr...68(VS.85).aspx
Old 06-17-2009, 10:08 AM
Thank you very much!
Old 06-17-2009, 02:24 PM
Glad to help,
Where did you hear about these 'HRTF_Full' or 'HRTF_Lite' options. Can't seem to find them in the docs.
Old 07-15-2009, 02:48 PM
Hey Paul,
Sorry it took us so long to get back to you. If you search in the docs for 'configuration settings' and go to 'miscellaneous options' near the bottom, the HRTF settings are in the description of 'sound3d.dx.algorithm.'
Do you know of a way to select multiple sound devices to use in DirectSound with Vizard? We've tried using the PySonic module, but we're having trouble getting Vizard to be able to use this with an import statement or a plugin. Any ideas? Either way (DirectSound or PySonic) would be great. Thanks again for all of your advice so far.
Old 07-20-2009, 01:05 PM
I got pySonic working by installing FMOD, the API pySonic wraps.
Get the "FMOD 3 Programmers API" from here:
http://www.fmod.org/index.php/download
Then copy the api/fmod.dll file into the same directory as your script.
Old 07-21-2009, 09:57 AM
Thanks again Paul!
orientation question whj Vizard 3 01-21-2009 12:22 PM
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
viztask question asimbh Vizard 1 11-20-2007 10:12 AM
Another color question mjabon Vizard 4 07-31-2007 04:04 PM
question about yaw, pitch, roll TunTun Vizard 2 05-23-2007 01:46 PM
