Old 07-13-2009, 08:29 PM
John P John P is offline
on the fly points
I'm doing a project where I use lots of on the fly objects. I'm trying to draw a single vertex but there seems to be a bug in that you must draw two or more vertices.
viz.startlayer(viz.POINTS)
viz.pointsize(10)
viz.vertex(0,2,5)
#viz.vertex(0,2,5.5) #this line will make it work..
p = viz.endlayer()
It seems that even with two vertices, if they are so close that they translate onto the same screen coordinate they will be culled. It could be a graphics card issue. This was really confusing me for a while so I thought I would drop this note.
Old 07-15-2009, 06:22 PM
A single point will be culled by the scene graph. You can disable culling on the object using the following code:
p.disable(viz.CULLING)
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 05:42 AM
3ds pivot points theuberk Vizard 16 07-21-2007 06:31 PM
Trafffic ideas.. anyone? k_iwan Vizard 13 12-10-2006 04:13 PM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 12:21 PM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 03:50 PM
