Old 05-20-2009, 06:58 AM
Sjaak Sjaak is offline
Wiimote in 4 sided Cave
I want to use the buttons of the Wiimote to travel (no rotation) through a world projected in our Cave.
How can I do that? I don't see an example in the help neither on this forum. There are examples with the keyboard that work in the cave.
#Create another tracker using the keyboard and mouse (arrow keys adjust position, mouse changes orientation)
origintracker = viztracker.KeyboardMouse6DOF()
#Link the keyboard/mouse so that it moves the cave and user around the virtual environment
originlink = viz.link (origintracker, caveorigin)
But the wiimote?
Something like this?
def CaveTravel():
#take the caveorigin and move
# I don't know what to put here
vizact.onsensordown(wiimote,wii.BUTTON_A,CaveTrave l)
thanks
Sjaak
Old 05-20-2009, 10:13 AM
Here is some code that uses the arrow keys on the wiimote to change the position of an object:
MOVE_SPEED = 5 # meters/sec
def WiiMove():
	elapsed = viz.elapsed()
	state = wiimote.state
	if state & wii.BUTTON_LEFT:
		caveorigin.setPosition([-MOVE_SPEED*elapsed,0,0],viz.REL_LOCAL)
	if state & wii.BUTTON_RIGHT:
		caveorigin.setPosition([MOVE_SPEED*elapsed,0,0],viz.REL_LOCAL)
	if state & wii.BUTTON_UP:
		caveorigin.setPosition([0,0,MOVE_SPEED*elapsed],viz.REL_LOCAL)
	if state & wii.BUTTON_DOWN:
		caveorigin.setPosition([0,0,-MOVE_SPEED*elapsed],viz.REL_LOCAL)
vizact.ontimer(0, WiiMove)
Let me know if this doesn't do what you want.
Old 05-20-2009, 02:05 PM
Thank you.
In your code you use a timer. Is it not better to react on event? I think the timer checks every often unneccesary. Or is that not possible.
I test the code next week.
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 11:29 AM
Four Wall Cave on One Computer envisC Vizard 1 04-28-2009 06:02 PM
Four-wall CAVE using two PCs dtidrow Vizard 5 03-24-2009 03:51 PM
Sending sound to Wiimote ? djdesmangles Vizard 1 07-31-2008 12:26 PM
wiimote and sensor bar masaki Vizard 1 03-06-2008 04:07 PM
