Old 03-15-2009, 09:13 PM
physics
Hi again, I'm doing a project and I'll need a lot of help.
I want an object to move in y axis and define a hotspot for it, then have another object which moves in x axis and at a point (hotspot) they will meet and collide.
I've been able to make them collide but my hotspot starts when I use my mouse, I want when my first ball reaches the hotspot the second ball goes to that position and collide.
I've done some things but it doesn't seem professional.
Please help me
here is my code:
viz.clearcolor( viz.GRAY )
viz.phys.enable()
viz.phys.setGravity(0,0,0)
ground.disable(viz.PHYSICS)
ball1 = viz.add( 'ball.wrl')
ball1StartPos = ball1.translate(0,0.2,9)
ball1.collideSphere()
ball2 = viz.add( 'ball.wrl' )
ball2StartPos = ball2.translate(4,0.2,9)
ball2.collideSphere()
BALL = 1
def onHotspot(id,x,y,z):
	if id == BALL:
		ball1.applyForce( dir = [ 0, 0, 1 ], duration=0.01, pos = ball2StartPos )
		ball2.applyForce( dir = [ -1, 0, 0 ], duration=0.1, pos = ball1StartPos )
#def animation ():
#	ball1.applyForce( dir = [ 0, 0, 1 ], duration=0.01, pos = ball2StartPos )
#	ball2.applyForce( dir = [ -1, 0, 0 ], duration=0.1, pos = ball1StartPos )
#animation()
viz.callback(viz.HOTSPOT_EVENT,onHotspot)
#Attach a hotspot to the duck.
ball1.starthotspot(BALL, viz.CIRCLE_HOTSPOT_IN, 0,0,20)
viz.MainView.translate( 0, 2, -10 )
Old 03-16-2009, 10:59 AM
A hotspot is triggered when the viewpoint enters or leaves it. Here you have a hotspot that will be triggered when you enter it
The radius of this circular hotspot is 20 meters so the viewpoint triggers it from the start.
It seems like a hotspot is not what you want here. Get the position of the first ball within a timer function and when it's at the position you want move the second ball towards it.
Old 03-16-2009, 10:32 PM
Thanks for your help, but what I want is something like proximity, instead of view entering a hotspot I want my object to enter that section and another action take place. Is there anything like proximity in vizard?
Old 03-18-2009, 08:47 PM
Question Help With Physics
please help me with the above problem
RE:Slide Joints and physics optimization nige777 Vizard 4 06-22-2009 04:21 PM
physics engine exception ad_astra Vizard 3 03-25-2009 11:31 AM
Physics and Haptics jalvarez Vizard 3 07-16-2008 03:03 PM
collision with physics enabled joeymax Vizard 2 04-17-2008 02:49 PM
Physics engine question adimov Vizard 2 07-22-2004 12:33 PM
