Old 06-10-2009, 01:10 PM
Woosuk Jang Woosuk Jang is offline
read method needed
Is there a method where I can continuously read data from a text file (such that, when a new data is written in that file while program's running, it reads that immediately) ?
Old 06-12-2009, 04:04 PM
The methods for reading and writing to files can be found in the Python documentation. What's the reason for reading it immediately after writing it to file?
Old 06-16-2009, 09:31 AM
Sorry for the confusion last time.
The program is supposed to read from a text file that is being written from another program. In my case the Vizard program is supposed to read a text file that Viewpoint is writing to. So I need a code that can help me to read continuously, because the text file is continuously being written, and I tried different methods with no avail.
This is my code so far:
file1 = 'file_name.txt'
file2 = open('marker.txt','a')
def linecount(fname):
""" Count number of lines in a file."""
f = open(fname)
nr_of_lines = sum(1 for line in f)
f.close()
return nr_of_lines
def readline ():
j = linecount(file1)
i = 1
count = 0
while count < 30:
if i <= j:
while i <= j:
line = linecache.getline(file1,i)
file2.write(line)
i = i + 1
#i = j
file2.flush()
yield viztask.waitTime(2)
count = count + 1
viztask.schedule(readline())
So what I did is two loops to read and write each line to a separate file ('marker.txt') as well as trying to continuously read in one second intervals. However, when I tested the program, it only reads up to the lines that were already present in the text file ('file_name.txt' or file1) right at the moment of initiation. Although it recognizes that there are new lines added (j increases) it doesn't read or write the lines.
Hope this is more understandable.
Thanks.
Old 06-22-2009, 06:49 PM
Please use code tags when posting code next time. Adding the following made it work for me.
linecache.clearcache()
parallel port method bionic1 Vizard 2 05-04-2009 07:41 PM
read from SP Moh200jo Vizard 1 02-19-2009 11:36 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
mapping method FlyingFish Vizard 1 07-12-2007 10:06 AM
method of a class instance not accepted as Callback Gilliard Vizard 1 08-10-2005 06:49 PM
