Old 04-15-2007, 01:52 PM
ghazanfar ghazanfar is offline
how to correct it
hi,
smiling problem is solved.
i have another problem. as i am using different animations of avatar.
and i am triggering animations at different time points.
the problem is that, when avatar walk towards a fixed point, then i perform a function , which made faces of avatars towards each other, after that 2nd animation. but before performing 2nd animation, avatars automatically perform an animation, which does not present in built in animation, like open their hands in " T " shape.( as also given in vazard Tutorial-->avatar-->tutorial.py).
how can i control this type of animation.
awaiting your reply.
Old 04-18-2007, 12:58 PM
Take a look at the following thread, specifically the last two posts. I believe it should address the problem you are having:
http://www.worldviz.com/forum/showthread.php?t=848
Let me know if you need more clarification.
