Old 02-04-2007, 10:40 AM
Jerry Jerry is offline
Mouse-drag an object
What's the best way to click on and mouse-drag an object
around the screen so that the object stays under the cursor?
Old 02-05-2007, 04:07 PM
In 3.0 you can link to a viz.Mouse linkable object. If the objects you want to drag are on the screen you could do a viz.grab( viz.Mouse, myScreenObj ) when you click on the object. This viz.grab() function would maintain the place where the mouse grabbed the object.
Also, you can do this all manualy. The vizinfo object does this and because it is implemnted in python all the code is there for you to see. Open the Vizard30/python/vizinfo.py file and search for "drag."
Old 02-05-2007, 04:19 PM
Here is a sample script that should work with 2.5
DRAG_TIMER = 1
balls = []
#Add 3 balls and place them in front of the user
for x in range(3):
	ball = viz.add('ball.wrl')
	ball.translate(x-1,1.7,4)
	balls.append(ball)
#Add a ground
ground.disable(viz.PICKING)
#Set background color
viz.clearcolor(viz.SKYBLUE)
#Disable mouse navigation
viz.mouse(0)
#The object that will be dragged
dragObject = None
def BeginDrag():
	global dragObject
	#Pick an object
	info = viz.pick(1)
	#Make sure object is one of the balls
	if info.object in balls:
		#Set the drag object
		dragObject = info.object
		dragObject.offset = vizmat.Vector(dragObject.get(viz.POSITION)) - info.intersectPoint
		dragObject.dist = vizmat.Distance(viz.get(viz.HEAD_POS),info.intersectPoint)
		viz.starttimer(DRAG_TIMER,0,viz.FOREVER)
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,BeginDrag)
def EndDrag():
	global dragObject
	#Stop dragging
	dragObject = None
	viz.killtimer(DRAG_TIMER)
vizact.onmouseup(viz.MOUSEBUTTON_LEFT,EndDrag)
def onTimer(num):
	if num == DRAG_TIMER:
		#Move the object based on mouse movement
		line = viz.screentoworld(viz.mousepos())
		begin = line[:3]
		end = line[3:]
		dir = vizmat.Vector(end) - begin
		dir.normalize()
		dir *= dragObject.dist
		pos = vizmat.Vector(begin) + dir + dragObject.offset
		dragObject.translate(pos.get())
viz.callback(viz.TIMER_EVENT,onTimer)
