Old 12-19-2006, 03:56 AM
krimble krimble is offline
wierd problem
I'm coding a virtual room with paintings, a spider and some textures with years on it.
Everytime I hit the spacebar the positions of the paintings, the spider and the years have to change (the positions are in a dictionary).
The problem starts when I add 2 lines of code with commands to change the positions of the years. (see the arrows on the end of those lines)
When teller == 2 it goes to except index error and it prints "consider it done". When I remove those 2 lines it goes through the loops and everything works normal.
What is wrong with those two lines ??? (i'm getting no errors)
def mykeyboard(key) :
	global volgorde, teller, teller2, speed
	if key == " " :
		try :
			if teller < 4 :
				bordTEX.texture(viz.add(B_blur[teller]))
				spider.translate(-19,5,13.05)
				spider.rotate(180,90,0)
				spot.translate(-17,5,-12.99)
				spot.rotate(0,0,180)
				print teller
				if teller == 2 :
					for getal in xrange(1, 15) :
						paintings[getal].texture(viz.add(P[volgorde[teller][getal-1]]))
						jaartallenDict[getal].texture(viz.add(jaartallen[volgorde[teller][getal-1]])) <----------
						spider.translate(POS_dict[s[teller-1]]['spiderPos']["translate"])
						spider.rotate(POS_dict[s[teller-1]]['spiderPos']["rotate"])
			else :
				teller2 +=1
				bordTEX.texture(viz.add(B[4]))
				bordTEX.scale(3,1.5,2)
				for i in xrange(1, 15) :
					# apply the paintingtexture to the paintings in the given order out of the volgordelist
					paintings[i].texture(viz.add(P[volgorde[teller2][i-1]]))
					# apply the jaartaltexture to the jaartallen in the given order out of the volgordelist
					jaartallenDict[i].texture(viz.add(jaartallen[volgorde[teller2][i-1]]))     <----------------
					# apply the jaartal textures to bord
					bordTEX.texture(viz.add(jaartallen[teller2-1]))
					# change the position of the spider per trial
					spider.translate(POS_dict[s[teller2]]['spiderPos']["translate"])
					spider.rotate(POS_dict[s[teller2]]['spiderPos']["rotate"])
					# change the position of the spot per trial
					spot.translate(POS_dict[s[teller2]]['spotPos']["translate"])
					spot.rotate(POS_dict[s[teller2]]['spotPos']["rotate"])
			teller +=1
		except IndexError :
			# end of experiment everything gets invisible
			kamer.visible(0)
			bord.visible(0)
			bordTEX.visible(0)
			spider.visible(0)
			spot.visible(0)
			for paint in paintings.values() :
				paint.visible(0)
			print "CONSIDER IT DONE!!!!!!!!!"
Old 12-19-2006, 05:09 AM
I've solved the problem, the list of of year textures was to short, STUPID !!!
