Old 12-04-2006, 12:53 AM
VAmanda VAmanda is offline
Using Avatar.Person
I have a couple of questions about using the Avatar.Person class. First, is there some way to pause the avatar's actions? More specifically, I have an avatar giving a speech using the following code:
speech = avatar.loadSpeech('speech.wav')
avatar.addIntentional(speech)
avatar.go()
I want to be able to press a key and pause the speech. If I call avatar.stop(), the animations stop, but the audio of the speech continues. Is there a way for me to pause this as well?
Also, I'm a bit confused on how to change the avatar's head/body using the Person class. I assume I'm supposed to use the replaceHead() and bodyType() methods, but I'm not sure how the number argument corresponds to the head or body that I actually want to use.
Thanks.
Old 12-05-2006, 12:15 PM
I modified the speak action to be pausable. I attached a zip that contains the modification and a script demonstrating its use. Requires Vizard 3.0.
Old 12-06-2006, 03:36 PM
The next release of Vizard will have a standard speak action which is pausable.
